Riser gaskets
Don S
If you are using OSCO, use their recommendations.<br />If you are using Mercruiser manifolds and gaskets use their recommendations.<br />Different gasket materials creates different methods.
Olds Eddie
Riser gaskets
Hello All! I am putting my new engine in the boat and had a question. The closed cooling system I have uses a block-off gasket for the risers. The last ones I used were a metal shim with gaskets bonded to both sides. The new ones I got are a thick green fiber material. I am not sure I trust them to handle cooling system pressure. What has your experience with these gaskets been like? Also Osco recommends Loc-Tite flange sealant on this joint, but I think I heard somebody say 'NO SEALANT!'. Thanks
yoced
Re: Riser gaskets
What Don said.<br /><br />Osco does not 'recommend' Loc-Tite flange sealant on the joint. Osco recommends a dry surface - <br /> - But, when on the phone, customers will often ask questions like 'but is it ok if I use sealant anyway..' or 'if i am going to use sealant anyway, what do you recommend..'and the Osco sales people will try to stear them away from silly-cone and into something like permatex #2 or some other very thin product.<br /><br />The thick C-4401 material that Osco uses for the block off gasket will work quite well under the closed cooling scenerio - as long as you retorque the riser after it gets warm. Maybe even retorque after a few hours of running also. That gasket material is very hard, and likes some time to take a set. I find it useful to leave bolted on for a few days first before it the parts are run, but most folks do not like being that patient.<br /><br />If you are worried, you could return your thick gasket for a set of thin gaskets with a metal shim, but it will cost more.
Olds Eddie
Re: Riser gaskets
Thanks for the input. I will use the green gaskets with the recommended waiting period and re-torque. I have made it a habit of re-torqing the manifold gaskets as I am running spacers between the block and manifolds, and with two gaskets to compress it just made sinse to do so.
Manipulator
Re: Riser gaskets
I wondered about this as well. I had a riser crack and had to replace it. I bought an Osco replacement. It said to put it together without sealant, but when I took the old factory one off, it had sealant on the gasket (both sides). I used sealant (permatex) when installing the new one and had no problems. Just don't cake it on.
