Parachute Adams
- Aug 17, 2013
- 32
First, I tested my tachometer and it received power but no signal. So I had local shop replace my bad rectifier and tested stator which is good.
Upon testing after repairs the tachometer still receives power and no signal. So obviously there is corrosion in the remote control area where the tach harness is connected.
Here is what I'd like to know:
I don't want to open the remote control and verify my thoughts that there is corrosion; too much of a pain to deal with opening the remote control.
Now, can I directly run a signal wire from source to the tachometer?
I think I can run wire from the Terminal Block directly to the tachometer. Correct?
Please help, and thank you for the help
WD
WD
