Fisherman_7
- May 25, 2013
- 8
I have a 1994 150 HP Evinrude Intruder and the speedometer quit working. Did some checking and the speedometer hole which is located on the lower gear case unit, was stopped up with some trash. I took a piece of wire and cleaned out the hole to make sure there was no more trash obstructing the inlet. Speedometer is still not registering at gauge. There is a small L shape or elbow fitting where the Speedometer tube hooks onto. Is it possible that the elbow is clogged somehow? Appreciate any advice you can give me to clear this up?
