Speedometer
webefishn
I have a Procraft 200 Combo with 200 Optimax. My speedometer quit working shortly after I purchased the boat. I have cleaned the intake hole on the motor and replaced the gauge. The problem seems as though it is disconnected somewhere inside the motor because when I blow air from the gauge I can hear the air inside the motor also no air is coming out of the intake hole. My question is that how can I get to the hose inside the motor? It seems like maybe there is a fitting that came loose. Any comments would be greatly appreciated. <br />--------------------------------------------------------------------------------
Kenny Bush
Re: Speedometer
You will probably have to take the lower foot off to get to the fitting for the pickup hole. Also trace the hose out of the boat and into to engine, and down the mid section. I have seen many hoses pinched, spliced, burnt, ect....
