Strange problem with YAM 115 4 stroke
polar2300
I'm new to outboards and I just bought a brand new polar 23 with twin YAM 115 4 stroke 2004. 25 hours on both engines that run great, however I get this strange and infrequent problem which happened since I got it. I can be running along just fine and then a random enging starts making a low pitched nose and loses some power but no alarms go off. I am then unable to get it back to full power but if I stop completely into idle and then accelerate the engines work fine. One time I did see seaweed come out of the back. The enging had its first break in service and everything checks out fine. I have regular props not aluminum ones.<br /><br />what's going on?? any ideas?? Is it seaweed in the inakes??
Mercathode
Re: Strange problem with YAM 115 4 stroke
Polar were you hitting bottom with one of the motors?
vinney
Idler puller on timing belt. Bearing in the idler pulley.
polar2300
Vinney: does that mean it needs to be retensioned?
vinney
Replaced if the bearing is bad.
rodbolt
hello<br /> it sounds like a fuel restriction somewhere. did the boat get rigged so that both engines draw from the same filter? you say that this problem will affect either engine at random? I doubt its mechanical due to the random nature. bearings gears and shafts dont normally fail then work then fail. mechanical fails and is finnished.<br /> try to post more info on the symptoms and rigging.<br /> good luck and keep posting
vinney
Agree that a fuel restriction will cause a fuel pump whine. We have seen some ildler puller failure. I would run the engine with a fuel pressure gauge and watch pressure. Its hard to believe it has two bad idlers or both engines where rigged improperly.
