are the lower units on a merc 228 and 260 interchangable? housing looks identical..
arty007 Petty Officer 3rd Class Joined Jan 7, 2009 Messages 86 May 1, 2009 #1 are the lower units on a merc 228 and 260 interchangable? housing looks identical..
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,349 May 1, 2009 #2 Re: swap lower unit merc 228 with 260? Series`1 and Alpha`s will swap.but not with the GEN II type
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,110 May 1, 2009 #3 Re: swap lower unit merc 228 with 260? Ayuh,... Should be the Same...
arty007 Petty Officer 3rd Class Joined Jan 7, 2009 Messages 86 May 1, 2009 #4 Re: swap lower unit merc 228 with 260? are they different as far as gear ratio? would it be better,worse,the same? my 260 housing has a patch on it.. looks like epoxy and im wondering if i can replace it with the 228
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,349 May 2, 2009 #5 Re: swap lower unit merc 228 with 260? The gear ratio`s are determined by the upper unit.
