Against All Odds
- Jul 12, 2015
- 7
Ok I have a 1987 Bayliner Cierra 2855. Powered by a 5.7 GM fairly fresh engine overhaul ( less than 200 hrs ago). The outdrive is the OMC Cobra I believe. I recently came across a really good deal on a mid to late 90's Cobra SX by Volvo complete setup including tilt, transom mounts and everything from another boat. My question is...Are these two units compatible with my configuration? As in will everything bolt on without any major alterations? I've read that these are very smooth and much more reliable. My current outdrive is wearing out and becoming more and more difficult to shift even after being adjusted by a reliable boat mechanic. As of right now it will not go into reverse. Also I believe the Cobra SX had a 5.0 engine in front of it before. Thanks!
"Experience is something you get after you need it."
