thermostat
MBAKER
Is there something special about the Mercruiser thermostat.... it looks to me like a typical chevy thermostat but in 160*. Mercruiuser part cost is 25$ +/-, I can get a stainless thermostat at the parts store for 10$ or less...
wrench 3
Re: thermostat
You can buy an aftermarket marine thermostat from this site for around $9.00.
tahoejag
Re: thermostat
I've installed aftermkt/auto store t-stat and no issues. I've heard that one difference is the type of metal made of (for anti-corrosion purposes?!?) or as wrench 3 says....on this site also.
Re: thermostat
Ayuh,... It's about the Temperature....
tazrig
Re: thermostat
You're paying a little bit for the name but mostly being able to get the 160 degrees.
MBAKER
Re: thermostat
I just checked at my local parts store, I can special order a Sierra that ends up being $23.99. Or I can get an off the shelf standard small block chevy thermostat in 160* variety for 3.99 or 8.99 for the premium one. I cant see any difference between the 2.
Don S
Re: thermostat
Check them with a magnet, if any part of them is magnetic, don't use them.
MBAKER
Re: thermostat
it was a no-go..... The one tried the height above the plate was too tall so they would not fit into Merc housing. Im sure there might be some variations of other brand that would have fit, but I just ordered the Sierra replacement and called it good. As it turns out I wasnt going to get it all done this weekend anyway, so not a big to wait another day at this point.
