fbriggs
- Mar 30, 2017
- 22
Rather new to outboard motors especially with tiller handle and mechanical advancing plate. Have a 1981 25hp EC25ECIM with electric start. Backfires when trying to start so I figure it is timing. I noticed that with motor in gear arent you suppose to be able to open up throttle and watch the timing plate actually move as you give it gas. Mine only moves about 1/2' and will not move the plate, figured will need to pull flywheel and try to determine what is froze or broke. Cant find any info on if there are timing marks to start off with or a linkage adjustment to start off with. Is there any site that would help explain this that anyone is aware of.
Thanks
Thanks
