tiny water drops on spark plug but plug is not white indicating head gasket leak
bonitoman
My compression is 135 on all 4 cyl on my 92 130 with 10 hours on my rebuild. Engine runs great at 55 mph 6 grand on the tach. Usually a plug gets cleaned from a head gasket leak. This #4 plug looks nice and tannish brown like the others. I did notice tiny water droplets. It is only on #4. Any suggestions. Thanks
ob
Re: tiny water drops on spark plug but plug is not white indicating head gasket
Only two concievable sources I can think of for water intrusion.One is contaminated fuel ,which one would think to be evident in more than one cylinder and the other is a leaking head gasket or exhaust cover gasket.<br /><br />Edit: I guess that's 3 concievable possibilities. ;)
bonitoman
Could it be the aftermarket head gaskets and gasket set that I picked up for the engine. I have always used these on omc engines. Are yamahas any different?
ob
I don't know.If it is a head cover gasket ,it may be due to a surface deformation .If you remove the head covers,try contact checking them without the gasket using some prussion blue.I assume they were torqued to the proper value and in sequence.
Justin H
You might check the exhaust plate. I had a Yamaha same problem replaced the head gasket and cover no help. Pulled the exhaust plate and found a pin hole in the plate allowing water into the cyl.<br /><br />Capt. Justin
