Walker2
- Sep 3, 2017
- 62
If using epoxy, use laminating resin, cabosil to thicken, 17oz cloth for skin.Replacing transom on '78 Chrysler Courier. I install epoxy floors for a living but dont know what epoxy to use for this application. I use Thixo or (cabosil) for a thickener. can I use that? Also what's the best fiberglass cloth to use over the back? TIAView attachment 349178
Thanks, Alldodge!!Use CSM (chop stran mat) with polyester resin.
Using 2 pieces of 3/4 plywood and bond the 2 together using CSM and resin
Some use corebond to bond the wood to the transom prior to covering and tabbing with CSM. Some just mix a thick resin and CSM to bond plywood to transom (what I did)
17oz (1700) biaxial cloth is best for epoxy for structural lams. CSM backing is not needed and will only become a resin sponge. If u use Poly, then 1708 or the like is generally used. I also use 7-10 oz eglass for non critical areas and stringer caps.Zool, Big thanks =] So I was looking at csm and can only find in 3 oz or 1.5 oz. I assume you're referring to another type cloth?
