Re: Trim Sending unit
The sending unit grounds through a mounting screw and then through a labyrinth of engine grounding jumpers. Mine was inop or flakey until I routed a ground wire directly to engine ground. Then all was good.
It's a variable resistor, and the wire routes up into the cowl, and then plugs into a pigtail on the harness. You should be able to read a varying resistance between that connector and ground. The wire routing is in harms way, and often gets injured.
hope it helps
John
