I apologize if this is not in the correct forum and I did try and search for the answer to no avail, but I do believe I read on how to trouble shoot this issue on here, so here goes. Both trim tabs will fully extend in the down position. After about 5 minutes the stbd tab will begin to retract and in 10 minutes is in the full up position. The cylinder is not leaking. I swapped the lines at the pump and the same problem happened, but now on the port side. So my issue is in the pump on the one side. What do I need to be looking for. I am told there may be a valve or something in there................??? Thoughts? Thanks for the help.
- RH
- RH
