Unknown Tilt/trim
Frank Acampora
Hey, RRitt--- Look what I just bought on Ebay for 40 bucks including shipping. Can you identify what it was from? The wiring terminations look original. The paint looks original. The pump was turned 90 degrees and I rotated it to the correct position for a Chrysler/Force trim system.
It was mounted on the aluminum plate you see in one photo and was wired to two OMC relays with a 50 amp circuit breaker.
I don't think it was used in this mounting because all ports are plugged. I did test the motor and it does work. Once I mount It on a set of trim/tilt cylinders I will test the pump.104_7188.jpg104_7187.jpg104_7186.jpg
Highlander70
Re: Unknown Tilt/trim
I think that might be the newer 3 wire setup but i am sure, he will let us know 4sure.
I just took mine off to send to him and mines 2 wires, 1988 125hp
as long as the valve body and everything is in good working order that seems to be a very good deal! nice find.
RRitt
looks like a one-off evinrude or mercruiser from before 1974. same thing as chrysler with different connections.
