gm280
- Jun 26, 2011
- 14,605
Okay guys, this is probably going to be a really stupid question. I see that so many resto projects talk about using Polyester and fiberglass clothe and CSM and even 1708 and I think I understand the terms and usages pretty good by now. However, I also read where most everybody talks about washing surfaces before applying the next stage of glassing up most projects and in between tabbing, filleting and such. And I think the use of Acetone is to wash off any dust and/or wax from previous polyester applications. But why Acetone and not Lacquer thinner or some other type-wax cutting solvent? Is there a special reason for the use of acetone verses lacquer thinner or am I missing something? I know you can't use any solvent that would leave an oily film behind (mineral spirits) because of adhesive capabilities would be in jeopardy. But if all you are doing is cutting waxes and/or dust buildup, wouldn't lacquer thinner do as well? The reason I ask is because I can purchase Lacquer thinner in my area cheaper then Acetone and Acetone flashes off quicker then Lacquer thinner meaning I know I would use so much more Acetone to do the job as well. Just wondering if I am missing the reason for the Acetone baths each time... Thanks for answering another stupid question from a resto beginner... :embarassed: :facepalm:
