Volvo 225e engine 8 cylinder
josephsiracusa
Is it possible to change the impeller on a volvo 225e engine while the boat is in the water? i somehow beleve once i pull the impeller housing cover off...water will keep coming in until boat and I sink? let me know thanks
skydiveD30571
Re: Volvo 225e engine 8 cylinder
Yes. You will not sink. Most of the cooling system is above the water line and the pump is not sucking water with the engine off.
Don S
Disconnect the inlet water hose from the pump, stuff a rag in the hose to stop the water till you get the impeller changed.
