Bt Doctur
- Aug 29, 2004
- 19,416
Curious, this motor uses a similiar HVS dist almost identical to merc. On a merc there is nothing inside but on volvo there is some type of electronics inside.
With the electronics unplugged the motor starts and runs normally, so what does this electronic gadget do or control. Thought maybe the tach but it works.
Story behind it is the motor dies and the comp was scanned and said dist problem. PO stripped a screw in the rotor and it fell out ,also broken was the inner mounting hole for the cap. Repair was replace the dist @ $1600 .Was going to drop in a merc dist but stopped when I saw the electronics and simply repaired what was broken with some 6-32 x 3/8 bolts for the rotor and some starboard for the broken mounting bolt. The mechanism inside the dist is similiar to a pickup but only has 1 notch about a 1/2 wide.
Anybody know ,dont have the eng serial number ,sorry
