Vortec 350 Removal in an AZ220DB 2007
Kioykid42
I'm trying to remove the 350 Vortec (froze motor, cracked head and block) from my 2007 Azure 220 DB. It looks like I have four (4) engine mounts that I can see, but what I don't know is how do I disconnect the engine from the outdrive. It has a duo prop volvo unit. Is there a repair manual that would cover it?
kenny nunez
Post a picture.
First, remove the drive then the electrical, then fuel, be sure to plug the fuel line after it is disconnected. Then power steering pump, throttle, water, exhaust hoses stringer lag screws, the 2 self locking nuts behind the flywheel housing and it should lift straight out.
Do not move the nuts on the front engine mounts. If you do then it will be hard to re set the alignment.
