Wakeboarding with no tower or pylon
zannneee
I currently have a boat where there is no option to attach a pylon or tower, and i was wondering if there is anything else i can do to help get bigger air. thanks!
Augoose
Re: Wakeboarding with no tower or pylon
That's a pretty subjective question- how much air are you getting now?
I'd go with the longest rope you can get away with, trim up a bit to get the stern lower in the water, and add ballasts if your boat has room. Use more speed into the launch on the largest wake you can get. You don't necessarily need a tower to get big air!
rallyart
What Augoose suggested plus make sure you have a zero stretch rope and improve your technique. Good luck.
