Captain Jeff
- Jun 15, 2005
- 159
It is difficult to get prime and get fuel to the engine. Once primed, I can start and run the engine. If I am only running at idle or low RPMs, the fuel line will run dry. I can feel air in the primer bulb and sometimes it is firm with air and I can't even pump fuel. Other times I am pumping and pumping and it takes forever to get fuel to the primer bulb.
This is on a 1999 Johnson 115. The entire fuel system has been gone through over the past couple years. Last season I rebuilt all 4 carbs, new VRO pump, rebuilt the vapor separator and primer solenoid. New fuel line from the tank to engine and a new water separating fuel filter and bracket. I can't find any fuel leaks anywhere.
I am going to replace the primer bulb tonight but does this sound like it could be a more serious issue? Also, does the orientation of the primer bulb matter? Obviously the fuel flow arrow is pointing towards the engine but can the bulb itself be horizontal or pointing up or down? Thank you
