What Bearing Puller?
Tsteiny
Trying to replace the top cover bearing cup on the upper drive shaft after replacing the seals. The race has some pits in it. In the manual I only see the parts number for the puller rod? I can’t seem to find any pullers that will fit so I can actually pull the bearing cup out. What did you guys use to pull it out? Can a I simple OTC slide hammer you can’t rent from auto zone work
dubs283
This is what I use. Need to clamp the top cap in a vise with rags as not to damage the finish
Get a slide hammer with multiple jaws, need to be smaller/modified to fit under the race securely. Shims can be damaged on removal so be prepared to replace one or more
alldodge
Blind hole bearing puller if I understand you correctly
https://www.amazon.com/blind-bearing-puller/s?k=blind+bearing+puller
kenny nunez
A propane torch should do it if you do not have an oxy/acetelyne rig. It usually does not take much heat to make it happen.
