Re: What is different of Craft and speed boat ?
If I may explain on your behalf tengirl,<br /><br />Guys, tengirl is looking for something to cruise around in with 10 or 12 friends, I think she is getting confused between a speed boat and a cruiser. When tengirl types 'catalogue' I believe she means 'category'.<br /><br />Tengirl, a speed boat is usually used for skiing or wakeboarding and they are usually a low profile (low sides), when you sit in them you are close to the water, close enough to dangle you hand in the water. A cruiser is typically much bigger, even though it may be the same lengh as a speed boat, it will have much higher sides (gunwales - don't pronounce the 'W') and is usually wider than a speed boat BUT some cruisers go very fast - you could call these a speedboat also. What you are looking for is a cruiser - the bigger the better.<br /><br />Aldo
