littlelund
- Jul 12, 2012
- 26
I'm restoring a 26ft islander with a 470 (170 hp) I'm going to run a new SE106 outdrive since the other one locked up tight on the upper. I have the engine on the floor and was a bit worried about it locking up so hard when the outdrive blew. But it still seems to run well. It has probably 1800+ hrs on it mostly trolling. guage reads 2029 but I know the key's been left on a time or two
It already has the alternator conversion on it, I need reliablity with this and have been told there are certain things that need to be done every so often on the 470's The cam and lifters being one of them due to cam walk or something. It does smoke a little on cold start up and I'm assuming it's rotted valve seals leaking a little. Can I get some advice from people who know these engines on what I should or shouldn't do. I'm thinking if bore checks out hone and re-ring pistons, new crank and rod bearings, polish crank, new cam kit with valve springs and seals, deck head and maybe a valve/ guide job. New oil pump and coupler while I'm at it. To much, not enough, run it till it blows.. What's the opinions.
Is there any reason hot rod engine builders couldn't handle the task of this engine as long as the specs and tolorances are known. I hear people say car guys don't understand marine applications and I'm not sure why if the specs are known.
