Where is the telltale; Suzi DT25???
stan_deezy
:confused: <br />Ok I am totally confused, bemused, and bewildered.<br /><br />I have been working on a recently acquired DT 25 poking and prodding a threaded hole at the rear of the lower cowl in an attempt to get water to pump through, with no success :mad: <br /><br />Must admit I haven't had a lot of time and no workshop manual, and any posts I found in searches said "Yes, there is a problem if your engine doesn't pee"<br /><br />Ah, but, here's the thing; I can run this engine for 30 minutes in the tank and still touch all the powerhead without heading for ER?<br />She's pumping water out through two holes just below the transom bracket and out through the above water exhaust; all sources run lukewarm.<br /><br />Today I decided to take my time and in a brightly lit workshop discovered that there is a hole in the starboard side lower cowl where I suspect the telltale was supposed to be. It still has factory blue paint intact on it so looks like it was never used. There is nowhere on the powerhead for a "take-off" to flow water out to this hole.<br /><br />Is it possible that I have an engine that never had a tell-tale??? :confused: <br /><br />Or has a previous owner/mechanic "blogged" the system for some bizarre reason???<br /><br />Any answers very gratefully received as it's driving me nuts and I am scared to use this engine at sea until I am sure I'm not going to have row home! :rolleyes:
boatster
Re: Where is the telltale; Suzi DT25???
What year is your motor? My 89 DT30 has a tell tale on the starboard side. It connects directly to the powerhead.
stan_deezy
1970's is my best guess, Boatster. Like I say, I can see where the hole in the lower cowl is for a telltale; it just doesn't ever seem to have been used???<br />There are no tappins in the powerhead that I can find to plumb into and she seems to run fine in the test barrel; perhaps I should try her on a small lake first so that I don't have so far to row/walk home??<br />thanks for the reply
bossee
Hi,<br />Maybe check DT25 parts list at http://www.brownspoint.biz (You must register).<br />I believe 1977 is the oldest DT25 they have parts list for (it is PDF file).<br /><br />I had a Suzuki DT65 before and the tell tale rubber tube is very short as You can see in the picture below.<br /><br />It is possible that Your DT25 should not have a tell tale rubber tube since it seems there is no water tube outlet on the powerhead (but I doubt).<br /><br /><br />Good luck!<br /><br />
Yepblaze
Many of the older models did not have a tell tail. <br /><br />They would however release water (after the thermostat opens) along with exhaust bypass out the big hole below the power head centrally located in the upper midsection.
stan_deezy
Thanks for the responses: great to know that there are other people who are willing to help when my "grey matter" fails to cool down!<br /><br />I decided that the engine probably never had a telltale fitted and then sold it!<br /><br />It was running fine and it came with a boat so I guess the guy got a good deal!<br /><br />thanks again
