turtle1173
- Nov 29, 2001
- 437
First, I want to thank everyone who has helped me get this thing running. Today I finally got her to go into gear without dying!! <br /><br /> While under load there was a very obvious and sometimes heavy white smoke coming out of the exhaust with the water stream. Understand that this motor hasn't run under load for 10+ years. Would this be normal?? I pulled the plugs and all 3 were wet with fuel, so it seems they are working. However I had little power like it wasn't hitting on all 3.<br /><br /> I did a search for "white smoke" and it seemed that white smoke indicated water in the chamber being vaporized. I have just replaced the head gasket and with wet plugs (from gas) it doesn't seem like this would be the problem.<br /><br /> Should I continue to run the engine even though I have the white smoke? Could the white smoke be because it hasn't been run in so long and there is perhaps some carbon burning off (or something)? Might this also contribute to the low power?<br /><br />Thanks again,<br /><br />Shane
