havoc_squad
- Mar 5, 2011
- 739
Two specifc questions:
Question #1 What technique is best recommended for installing the Wiseco piston circlips when putting the final clip in? When practicing on the old OEM piston, I can consistently use the plastic handle flat square screwdriver and push the end part of the clip into the groove at the end. Or at least far enough that I can use the tip of the screwdriver to pop it into place.
The first Wiseco circlip I was able to use a technique shown on Youtube by pushing the circlip gap facing up, then swing the clip open end facing opposite of the circlip notch in piston.
The problem with the Wiseco is the OEM piston circlip technique option isn't possible, the design geometry of the hole won't allow that.
Question #2. In practicing how to get the first circlip in and struggling for a long while using the flip techinque but with the open end facing down, the ends scrapped up the anodized gray coating on the first piston wrist pin hole I was working on.
If my fingers do not feel any ridge/scrap, is this okay or do I need to pay for a replacement piston? I might be able to get photos of this if needed (I hope).
