palmbeach161
- Dec 30, 2009
- 10
New to boats and outboards. Bought this outboard in 2008. At sea trial it would not power up when in gear--idle fine. Previous owner had carbs cleaned--ran fine. Sat up over winter. Spring 2009 would not power up--carbs cleaned --ran fine, end of summer 2009 sat up for a month--would not power up. Carbs not yet cleaned. After reading many posts on this great site I will remove all old gas and Ethanol and replace with fresh, use Stabil marine at strong dose, install Racor water separating filter (10 micron). My questions are: Will the carbs being gummed-varnished up cause the motor to sneeze, cough and occasionally cause a large quantity of air bubbles to come out of the exhaust? Also is draining the carb bowls better than running the motor out of fuel? Would a 2 micron filter be better than a 10? I have bought a Yamaha Service Manual and will clean the carbs myself this time. Cannot afford to pay $350-400 to do this. I have cleaned and installed carbs on trucks, tractors, mowers and other IC engines for years. Does anyone have any cautions-suggestions before I do the carbs on this Yammy? Thanks in advance for any replies.
