Yamaha 130, still need help
McCrank
Loss of power, totally boggs down after 2200rpm. No alarms, no heat or oil problems, no obvious loose wires or leaky fuel lines. Year 2001 model with <100 hours on it.I will be putting the carbs back on tonight but upon inspection they looked cherry so I don't suspect them. Any thoughts on whats happening to it? Auto-protect features with no audible alarms ect..? Oh yeah, linkages all look good also, This really has me scratching my head.
Ray Neudecker
Re: Yamaha 130, still need help
Do a compression check and if good go to the fuel system. A stuck anti siphon valve ball or a clogged fuel seperator would be the first suspects.
McCrank
Thanks Ray, I just got back from the boat ramp. It was the carbs I guess. After soaking them overnight in carb cleaner & blowing them out, she runs better than ever.
My 130 had a similar problem as you describe except it wouldn't rev out past 3200rpm. Ended up being a faulty spark plug.
