I have been reading through these forums for a few hours now and I am convinced I have a fuel related problem.<br /><br />I have a 2001 Yamaha 250hp 0X66 (EFI) Saltwater Series.<br /><br />It has just recently started to give me trouble when getting on a plane sometimes. It also will lose power randomly (8-12mph). Before I begin applying the suggestions I have read here I have a few questions.<br /><br />Can I perform the fuel pressure tests out of the water with a hose hooked up to the engine?<br /><br />What should my WOT RPM be on this engine?<br /><br />What octane gas should I be using?<br /><br />What plugs would you reccomend?<br /><br />Also, there is a little fin under the cavitation plate, I beleive it is called an anode? Well, mine fell off while running. Is it OK for me to use / work on the outboard with this peice missing? <br /><br />Link to picture of 'anode': http://www.eshop.msn.com/trackoffer.aspx?p=1085:1:1:9651:7:9651: 0:9:1:0:0&merchId=2776&invMerchModel=326790862<br /><br />Thanks a ton.
