Yamaha puddle fuel system- What is it???
hawilson2
I have a 1996 Yamaha C115. I was looking at the<br />manual and found mention of but no info on the puddle fuel system. Can someone explain its purpose and how it works or point me to a place on the web where I can get info about it?
rodbolt
Re: Yamaha puddle fuel system- What is it???
hello<br /> puddled fuel in the intake track is a problem with all two strokes at low speeds. to assist in this puddle problem most manufacturer's design a drain system to route the puddle fuel to the next cylinder.<br /> some yamahas use pulses from the intake track and the piston and some use a check valve in the block. to tell you will have to look it up on the parts book. if it says check valve its a valve if it says nipple its a nipple. if its a valve you can test it by sucking and blowing through it with a syringe and tubing. air should flow only one way.<br /> good luck and keep posting
