YAMAHA PUMPS TO MUCH OIL-HELP
IBSWAMPY
I HAVE A NEW 2003 YAMAHA 130 HP, IT PUMPS TO<br />MUCH OIL TO THE TANK ON THE MOTOR, IT SMOKES VERY VERY BAD, HAD OIL ALL OVER THE BACK OF THE BOAT AND IN THE WATER, IT PUMPED ONE GALLON.<br />CHECKED FLOAT WITH OHM METER SEEMS OK, BUT PUMP SEEMS TO RUN UNTIL OUT OF OIL ON THE BIG TANK.<br />THIS HAS HAPPENED 3 TIMES IN 4 TIMES OUT WITH NEW MOTOR. HOW DO I FIX??
JB
Re: YAMAHA PUMPS TO MUCH OIL-HELP
Moving to Yamaha Troubles
Ray Neudecker
The most common cause is the oil sensor in the tank. Since it is a new motor, a return to the dealer would be the best fix.
