Kasco Marine De-Icer Time/Temp Control
Ships: In 1 Business Day
Using a Kasco 1/2hp, 2400D De-Icer and a C-20 Controller, you can avoid the hassle and expense of removing your dock and boat for as little as $15 per month!
The C-20 Time and Temperature Control Box is designed to utilize BOTH the Time AND Temperature features. By utilizing both functions, you can save power by only having the De-Icer running while it is cold enough and in set time intervals. It is recommended to have the unit on in at least 2 hour intervals to set up a proper circulation. Each situation is different and the amount of time needed to maintain an ice free area will differ accordingly. Also, conditions do vary during the year so operation may have to be altered to fit the conditions. Please see the link to Owners Instructions below to see installation and operation instructions, as well as operation recommendations.
The timer pins should be pulled upward for the desired time frame the De-Icer should be set to run. The thermostat dial should be set to the outside temperature the De-Icer should operate. When, and only when, the temperature drops below the temperature the thermostat is set in a time frame that the timer is ON (pins pulled upward), the De-Icer will operate.
Click here to see owner instruction manual.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
