SeaDek® 16"X 39" 13mm - Specialty Large Helm Pad
Made to order
Ships: In 3 Business Days
The Helm Station Pad is a large, 16" x 39" helm pad. SeaDek Helm Station Pads provide the utmost of comfort while standing for long hours on the water. Made from closed-cell PE/EVA blended foam material, this soft yet durable pad features 13mm foam that absorbs impact and an embossed surface with exceptional non-skid characteristics to provide safety and stability. The Helm Station Pad is backed with our 3M™ pressure sensitive adhesive for an easy peel-and-stick installation.
Helm Station Pad Installation Instructions
The only items you'll need for your installation should be a sharp razor blade, masking tape, window cleaner and a clean cloth.
Thoroughly clean the area where SeaDek will be applied. We recommend using a cleaner that will not leave any residue. A glass cleaner used with a clean cloth or scotch-bright pad works well. Make sure the area is completely dry before applying the pad.
If there is any glue, grease, adhesive or other substances on the area that the pads are to be applied, mineral spirits followed by acetone may be used to remove them. Be sure to use a glass cleaner afterwards as suggested above. Again the surface must be completely dry before applying the pad.
If pads are being applied to a new boat right from the factory it is very important that all mold release is thoroughly removed from the boat surface. Be sure to check with the boat manufacturer before applying pads. Arrange the pad to the exact location to be covered and verify proper fit and placement. Once you are sure the pad is the right size and are happy with the location turn the pad over so that the paper backing is facing up. With a sharp razor, carefully cut the paper backing right down the center being careful not to cut into the pad. From the center, peel up each side a little to make sure the backing is completely cut all the way through.
Turn the pad back over and reposition the pad exactly where you want it to be installed. Firmly secure one side of the pad to the application area using two-inch masking tape.
Now lift up the untapped side of the pad with one hand and loosen the paper backing with the other. This process is a little easier if you have someone to help you out. Slowly and carefully pull up the rest of the backing while applying the pad to the platform. Use your hand to apply pressure to the pad to assure a firm bond between the pad and the platform. Now remove the tape from the other side of the pad and repeat the application process just like you did on the first side. Take time to press the entire pad into place with your hands especially around the edges of the pad.
Helm Station Pad Features
SeaDek manufactures the finest helm pads on the market today. Made from closed-cell PE/EVA blended materials, specifically formulated for the marine environment, SeaDek's Stock Helm Station pads features 13mm foam to absorb impacts and micro-dot embossing on the surface for durability and safety. Available in two sizes, 14"x36" and 16"x39", color options are White over storm gray, Caribbean blue over storm gray, Seafoam Green over storm gray, Beach sand over black, Black over storm gray, Storm gray over black, Cool gray over storm gray, Mica over black, Army camo over black, Faux teak brown over black. If the two standard sizes won't work, SeaDek offers custom helm pads as well. You can even have custom text, logos or graphics routed right into the pad.
Stock Helm Station Pads: 14"x36" and 16"x39" available in a variety of colors. Embossed surface.
All SeaDek products feature 3M™ pressure sensitive adhesive. Simply pull the backing off and press the helm pad into place. Your pad stays put and so do you.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
