Blaster II 3.5 GPM Washdown Pump
10  Saves
Brand
Shurflo
Out of stock
Only %1 left
SKU
IMF-1388197
Ships: In 1 Business Day
Need Help? Call 1-800-869-1686
Manf. Part # 4238-121-E07 - Shurflo Blaster II 3.5 GPM Washdown Pump, 12V
ProBlaster II 4238 Series four-chamber washdown pump combines quality and value. Perfect for tough washdown applications such as fish box, scaling, and anchor chain cleaning. These rugged, self-priming pumps deliver 6' of lift, can run dry without damage, and won't overheat with extended use. Seamless motor shells are E-coated and have O-ring protected end-caps. Ignition and thermal protection. Sealed switches. Includes a pistol grip plastic spray nozzle & fittings. Direct replacement with same mounting bracket as ProBlaster 3901.
  • GPM: 3.5
  • PSI: 45
  • Volts: 12
  • Amps: 7.5
  • Size: 9" x 5" x 4-1/8"
Manf. Part # 4238-141-E07 - Shurflo Blaster II 3.5 GPMWashdown Pump, 24V
  • GPM: 3.5
  • PSI: 45
  • Volts: 24
  • Amps: 3.5
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
California Prop 65 WarningWARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
Write Your Own Review
Only registered users can write reviews. Please Sign in or create an account
Copyright © 2024 BOATING INVESTMENT GROUP LLC., - IBOATS. All rights reserved.
