Jabsco HotShot Automatic Washdown Pump w/Hosecoil - 5.0GPM - 70PSI - 24VDC
1  Save
Brand
Jabsco
$216.98
Out of stock
SKU
IB00389268
Mfg
82905-0094
UPC
671880623537
Ships: In 1 Business Day
Need Help? Call 1-800-869-1686
The HotShot Series robust five chamber, patented co-injected molded diaphragm and larger heavier duty motor brushes significantly extends pump life by up to 50%.
Features
  • Flow: 5.0GPM OR 18.9LPM
  • Fitting: 3/4" Hose Barb
  • Sealed switch and co-moulded diaphragm, eliminates leak paths, extending the life of the pumps by up to 50%
  • Ergonomically designed spray nozzle provides powerful and accurate fire
    power with every shot
  • Quick Disconnect Ports allow for adjustable and ease of installation
  • Kits include spray nozzle, fitting, Pumpgard strainer and hose
  • Improved noise Dampening Rubber Feet, significantly minimizes vibration
    when mounted against hard surfaces
  • 24VDC
  • Certified to EN ISO 8846 Marine (Ignition Protection)
WarningWARNING: This product can expose you to chemicals including NICKEL (METALLIC) which is known to the State of California to cause cancer. For more information go to P65Warnings.ca.gov.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
California Prop 65 WarningWARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
Write Your Own Review
Only registered users can write reviews. Please Sign in or create an account
Copyright © 2024 BOATING INVESTMENT GROUP LLC., - IBOATS. All rights reserved.
