Jabsco Maxi Puppy 3000 12V Flexible Impeller Pump
Maxi Puppy self-priming pump 12VDC. Ports ½” BSP threaded (use ¾” hose adapters), plus connections for 25mm (1”) bore hose.
Features:
- Connections: - for 25mm (1”) bore hose or 1/2" BSP
- Dimensions: - 220mm long, 120mm wide, 85mm high
- Fuse Size: - 25(amp)
- Output: - up to 45 litres/minute (10 gallons/minute).
- High capacity, continuously rated bilge pump
- Self priming up to 2.4m vertical lift
- Simple, fully serviceable design with few wearing parts
- Can generate pressures up to 1 bar (15 psi)
- Bronze body, stainless steel shaft
- Packaged Dimensions: L:28.00 x H:13.00 x W:15.00cm
- Actual Weight: 3.85 Kg (Approx. 4.35 Kg packed)
WARNING: This product can expose you to chemicals including LEAD which is known to the State of California to cause cancer, birth defects or other reproductive harm. For more information go to P65Warnings.ca.gov.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
