Jabsco PAR-Max Washdown Pump Kit - 4.0GPM - 60PSI - 24V
Ships: In 1 Business Day
Washdown pumps are ideal for cleaning decks, cockpits and anchors on yachts of a range of sizes and can be connected to sea or fresh water. Comes with an intake strainer, spray nozzle and quickconnect 3/4" hose barb fittings.
Features
- Flow: 4.0 GPM
- Fitting: Connections for 3/4" ID hose
- Dimensions:7.8" long x 4.0 wide x 4.0 high - 5lb
- High pressure jet blasts mud and silt from anchor chain and decks
- Waterproof with sealed motor and sealed pressure switch for mounting in
exposed positions - Thermal overload protection automatically stops the motor if it overheats
- Dry Running
- Soft Rubber mounts
- Corrosion resistant
- Complies with USCG 183.410 and ISO 8846 MARINE (Ignition Protection)
- Supplied complete with Pumpgard abd trigger nozzle
- Suitable for high pressure applications
- Self priming up to 10ft (3M)
WARNING: This product can expose you to chemicals including NICKEL (METALLIC) which is known to the State of California to cause cancer. For more information go to P65Warnings.ca.gov.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
