Shurflo PRO BLASTER II Washdown Pump Deluxe - 12 VDC, 4.0 GPM
Ships: In 1 Business Day
SHURFLO's PRO BLASTER II washdown pump delivers superior performance that customers have come to expect and rely upon. Whether it's blasting away the grimiest decks clean, fish box scaling and anchor chain cleaning, SHURFLO's PRO BLASTER II washdown pump delivers high performance that provides a powerful consistent spray pattern. Built to withstand the marine environment with electro-coated motor, O-ring seals, fully sealed wire entries and can run dry without damage. Inlet strainer, 1/2" hose barb fittings and nozzle included. Ignition protected. Thermally protected.
Features:
- 4901 Replacement
- Sealed Switch
- Sealed Motor
- Corrosion Resistant Electro
- Coated Motor
- Independent Chambers
- Built-In Check Valve
- Co-Molded Diaphragm
- Self-Priming up to 6 Feet
- Dry Run Capability
- Thermally Protected
- Ignition Protected, CE
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
