Ocean Signal SafeSea E100G GPS EPIRB - Cat1 w/Auto Release Housing
Ships: In 1 Business Day
Features:
- E100G EPIRB incorporates a state of the art 50 channel GPS receiver for fast and accurate position acquisition
- Manual bracket, manual release housing and float free housing options
- Extreme battery life even at low temperatures
- In excess of 96 hours operation
- User replaceable batteries with five year replacement interval
- Intuitive operating controls protected from accidental activation
- Meets or exceeds all International standards
- Class 2 EPIRB (-20°C +55°C) for general use
- Non hazardous battery
SafeSea EPIRBs operate in the 406MHz satellite band monitored by Cospas-Sarsat, the international satellite operator, ensuring a signal can be located wherever it is activated around the globe.
SafeSea EPIRBs are also fitted with a 121.5MHz homing beacon and a high brightness LED strobe light for fast on-scene location.
The SafeSea E100G EPIRB benefits from a dedicated built-in GPS which sends a highly accurate position, greatly reducing search time.
With the SafeSea EPIRB battery operating life being the highest in the industry an Ocean Signal EPIRB keeps rescue services updated with your location for longer.
406MHz Satellite Transmitter
- Frequency: 406.037MHz
- Tolerance: +/-1kHz
- Stability: 2ppb/100ms
- Output Power: 5W (nominal)
- Modulation: Phase +/-1.1radians (peak)
- Emission Designator: 16K0G1D
- Encoding: Bi-phase L
- Data Rate: 400bps
- Duration: 520ms
Low Duty Cycle Strobe Light
- Light Type: Dual high intensity LEDs
- Light Colour: White
- Output Power: >0.75candela
- Flash Rate: 20-30 flashes per minute
Battery Type Lithium Primary
- Chemistry: Manganese Dioxide (LiMnO2)
- Operational Life (E100G Class 2 with LB2E): typically 96hours
- Replacement Interval: 5years
121.5MHz Homing Beacon
- Frequency: 121.5MHz
- Stability: +/-50ppm
- Output Power: 25-100mW PERP
- Modulation: Swept Tone AM
- Emission Designator: 3K20A3X
- Modulation Depth: 85-100%
- Sweep Range: 400Hz 1300Hz
- Duty Cycle: 35-55%
GPS Receiver (E100G only)
- Sensitivity Cold Start: -146dBm
- Sensitivity Re-acquisition: -162dBm
- Satellites channels tracked: 50
- GPS Antenna: Microstrip patch
Environmental
- Operating Temperature Range: -20°C to +55°C
- Storage Temperature Range: -30°C to +70°C
- Automatic release depth: 4M (max)
- Waterproof: >10M at +20°C
- Drop into water: 20M
Standards and Approvals
- Cospas-Sarsat: T.001 / T.007
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
