High Performance Rotary Tilt Helm for Single Cable
- Specifically designed for high performance and high efficiency applications.
- Tilt range of 48° and five locking positions.
- Tilt device eliminates underdash movement.
- Standard 3/4” tapered shaft - stainless steel.
- Engine side stainless steel cable output end featuring patented gasket, engine side.
- Made of corrosion resistant materials.
- Use with M90 Mach cable.
- Use with X82 Tilt Mechanism.
- Stroke: 9”.
- Lock-to-lock steering wheel turns: Approx. 3.8.
- Maximum steering wheel diameter: 16”.
- Suggested steering cable bend radius: 7.87”. Minimum steering cable bend radius: 5.9”.
- Not to be used on boats equipped with engines that exceed the maximum horsepower rating of the boat.
- SKU
- IB-T101
$252.89
Checking stock
More Information
| UPC Code | 702755043973 |
| Vendor Name | Uflex |
| Length | 10.5 |
| Width | 7.5 |
| UOM (Sales) | EA |
| Vendor Part No | T101 |
