High Performance Zero Torque Rotary Tilt Helm for Single Cable
  • Specifically designed for high performance and high efficiency applications.
  • Tilt range of 48° and five locking positions.
  • Tilt device eliminates underdash movement.
  • Standard 3/4” tapered shaft - stainless steel.
  • Engine side stainless steel cable output end featuring patented gasket, engine side.
  • Made of corrosion resistant materials.
  • Use with M90 Mach cable.
  • Use with X82 Tilt Mechanism.
  • Stroke: 9”.
  • Lock-to-lock steering wheel turns: Approx. 3.8.
  • Maximum steering wheel diameter: 16”.
  • Suggested steering cable bend radius: 7.87”. Minimum steering cable bend radius: 5.9”.
  • Not to be used on boats equipped with engines that exceed the maximum horsepower rating of the boat.
SKU
IB-T103
$356.69
Checking stock
More Information
UPC Code 702755043980
Vendor Name Uflex
Length 11.8
Width 7.55
UOM (Sales) EA
Vendor Part No T103
