Stingry331
- Apr 19, 2002
- 5
If anyone can help I have a 1989 Bayliner with a 1988 force 125HP outboard. The problem is the power tilt/trim will not go up or down. the motor sounds fine when you hit the switch but nothing moves, if I hold the switch and pull the outboard at the same time it will lift. I took the hydraulic lines off the valve body and capped them off the outboard slowly falls down. If anyone knows what to try first all help is appreciated. Thanks.
