Re: Compression Test
It should be on the control s or very close by. It is the switch that you are suppose to connect to the operator in case you go overboard. When it gets pulled out , the switch will kill the motor.<br />Just disconnect 1 wire at a time, pull the plug, reconnect to that plug, and put the plug in such a position that the metal on it touches the engine housing block securely. Naturally , it will be sparking so watch out for fuel fumes and keep a fire extinquisher very handy.<br />I've checked compression at dockside but you run the risk of dropping your tools in the drink or worse yet, getting your leg smashed by the boat when a wave comes along. A better method would be at home using muffs or better yet a makeshift test tank. Same deal, warm it up and turn it over a few times on each cylinder you check.
