I've got a 1984 9.9 Force. At the beginning of the season it ran great for about 10 minutes. Then it blew a head gasket. I replaced the head gasket and the impeller, althought the one in there looked really good. The cylinders looked good when I took the head off, I also checked out the fuel pump and the exhaust chamber while I was working on the motor. All looked good.<br /><br />Now the problem. After the repair it would start right up then die soon after. I checked the fuel level, cleaned out the carb, and checked the points gap. All seemed good. <br /><br />Then it wouldn't start at all. One cylinder would not fire. I switched the condensor and the points between the two cylinders and still it won't fire in the same cylinder. I think it's a coil but does anyone see where I might have gone wrong in checking out this engine.<br /><br />I don't want to spend much on this guy, this is why I'm posting this question. This motor is just a couple of days from becoming a boat anchor it I can't fix it cheaply.<br /><br />One more thing the compression came out 80 and 78.<br /><br />Thanks for any help.<br />Cam<br /><br />PS: I will probably be looking for a good condition 9.9 in the Detroit area even if this engine gets fixed. We just need to have some faith that the engine won't crap out on us. So if anyone knows of a good used one, let me know.
