Does anyone know the approximate current Draw on the Force/Chrysler Power Trim Motors. I will be installing aftermarket relays and need to get large enough? Don't want to burn up the contacts.<br />Thanks<br />John
10Amps nominal (less idealy, more as the brushes wear), so if it were mine, I'd go with 15AMP relays, 20AMP fuse protection,and #12 stranded auro wire minimum.
