Hoping someone can help me...<br /><br />Just bought a 92 Maxum with a 92 Force 70HP OB. Worked great for a little while, then completely cut out. Here's what I've done so far...<br /><br />- Disconnected kill wire from switch box.<br />- Checked for spark on all 3 cylinders during crank, none.<br />- Checked voltage to switch box from stator, 8.5V (I assume it's the red and blue wires?)<br />- Checked trigger inputs to switchbox, voltage present, but small (I don't have a peak meter, just going by feel with a DVM on that one)<br />- Checked outputs from switchbox to coils, no voltage read at all (again, w/out a peak meter, just a DVM)<br /><br />I've seen in the forum references to a systematic problem with this ignition system. Can't determine the right path to go down though.<br /><br />Also, the manual says that maintenance-free bateries are not recommended. Boat came with one. Possibly related? <br /><br />Any tips at all would be GREATLY appreciated. <br /><br />Thanks,<br />Greg
