Pulled the head and cleaned water ports. Replaced head gasket. New waterpump housing/impeller. Motor runs good. Get excelent water flow in trash can high and low rpms. Run the motor at full throttle on water. Water flow is not steady. It serges out about once a second. Motor got hot. Pulled the thermostat and tried it again. Still water serges from leg but doesn't seem to get hot. Temperature gage is all or none. Block seems cool to the touch. Is this serging normal at higher speeds? Is this enough water? Does some water exit out the exhust port below surface of water? Is this border line for overheating? Any suggestions?<br /><br />Thanks
