i was talking to u about cylinder head gasket i took the boat in to marine shop they did a compression check to start 165 psi on all cylinders within small variance on a couple,but they noticed some water geting in to the cylinders,they said the head gasket was leaking but not into the cylinders,they removed exhaust cover and exhaust plate was uneven said it should be flat and gasket were not in very good shape,they think this is why water is in cylinders,does this make cents,i thought that was for exhaust only,how could water get in there,unless crack in cylinder,but wouldnt that show up in a compression check that isnt an area where water is circulating is it? 1997 force 120 hp
