1969 105hp purple wire?
beach
What is the purple wire used for in the harness at the dash? Additional guage?
Terry H
Re: 1969 105hp purple wire?
I think the purple wire is for a tach...just a Thought
lonewolf5347
Thought101 YOU ARE CORRECT OLDER FORCE ENGINES IS PURPLE AND NEW MODEL ARE GRAY FOR THE TACH.
force01
The purple wire was used for charge indication, usually a light in the old days. The older motors used white for their tachometer signal. Bret<br /><br /> If you need further assistance please email me @ forcepower01@yahoo.com. thanks,Bret
beach
Thanks Bret,<br />My tach circut is white. Would I just wire in a lamp to be lit by the purple lead when the system is charging?
The Marine Doctor
The Purple wire can be used for a volt guage or a light.<br /><br />If you look back on your engine, there should be a terminal block that tells you what the wires are for.<br /><br />TMD
beach
The manual says generator but then (not used). Was just trying to figure out how I can put it to use since I want to get the charging system working.<br /><br />The manual says to used a self lit test lamp for most of the diagnostics. Can another meter be used? I have multi meters and ohm meters.<br /><br />Thanks
