HookLineAndSinker
- Oct 7, 2003
- 2
Just mounted a used 105HP Chrysler on my boat. Not my car.
<br /><br />I hooked water up to the lower end. Then cranked it up -- and it started... but no dice on water coming out of the water vent. <br /><br />I Even tried putting a barrel of water under the bottom end with the water level above the intake, but it still wouldn't pull it through even at low speed in Forward gear. (I also tried removing the thermostat)<br /><br />Replace impeller? <br /><br />David
